Whirlpool wtw5000w3 New lid Lock added, doesn't lock no Knob options!
I just replaced the whirlpool lid lock with one that is normally Partially open stopping the striker from entering.
Parts store said it opens up when connected to washer. So far it hasn't done so.
I manually push in the main sensor switch fool it to be closed then try to run the washer.
When turning the knob the led doesn't light up any options. Unable to select any.
I am able to select the diagnostics. I recalibarated used the spin and drain test. errors showup in diagnostic.
F41 E1 Lid Switch Fault
E41 E21 Lid Unlock Fault
F41 E2 Lid Lock Fault
F421 E41 Shifter Fault. The Actuator was removed and tested before replacing the Lid Lock.
I am thinking the control board shorted when removing the old Lid Lock. But the Led behind the controller is lit and I was told that means its good. But seems to only partially good.
1st question and lid locks normally partially open?
2nd question clearing the errors will remove the errors hence will show up when recalibrating if they are still there.
Please someone help me setup the washer. Thanks.
