メインコンテンツにスキップ
HP ZBook 15 G4 Mobile Workstation.
3回答 すべてを表示
How do I instal a new SSD with a heatsink in my laptop
I bought a new SSD, but I don't want to just install only the SSD. I'll like to install it together with a heatsink for the SSD. Is this possible for my laptop? Is there enough space in my laptop to install the SSD with a heatsink?
If the answer is yes:
a). How do I go about this?
b). What is the best heatsink you'll recommend for the job?
If the answer is no, any ideas on how to keep the SSD running cool and not overheat?
Also, what is the best thermal paste you will recommend for my laptop processor and Graphics card?
The laptop is HP ZBook 15 G4 Mobile Workstation
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi @bangkok30182
According to the specifications for the laptop it has PCIe 3.0 (Gen 3).
Gen3 NVMe/Sata SSDs don't usually get hot enough, even under heavy loads, to require a heatsink as such. They come with a heat exchanger in the form of copper strips built into the sticker, which is usually enough.
Gen4 (PCIe 4.0) NVMe get very hot, especially when loaded down. So you will need a heatsink, but it will only run at Gen 3 speeds anyway in your laptop, so it might not get that hot but they come with a built in heatsink also.
Here's the maintenance and service guide that may help.
You could open the laptop and measure how much room there is on top of the SSD to fit a heatsink. See p.40 in the manual.
You will then have to find suitable heatsinks that may fit when the laptop is closed. Search online for SSD heatsinks.
How much ram is installed in the laptop? If the SSD is running hot it may be because there's not enough ram and the SSD has to work harder. The laptop supports up to 64GB of ram. See the specifications in the link above.
As to thermal paste, ifixit discourages recommendations as they can be too subjective and may be misconstrued as spam by the ifixit spam filter. It also creates problems in questions/answers with people linking spam websites with various products. Doing your own online research is probably best.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Bangkok さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 37
過去 30 日: 102
今までの合計 179
