Black screen only after front panel replaced
Once front panel replaced, screen is black....I can hear messages coming through and vibrate is working
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I think I've narrowed it down to wrong equipment.....the model #'s are the same as the 4S, not the iPhone 4
このアンサーは役に立ちましたか?
If you have checked all your connections and it still doesn't work then you may have trapped the LCD flex cable and bent it whilst installing the front panel, this would result in a black screen. You would need to buy a new one.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 597
1件のコメント
Any luck on this? i'm having the same problem.... already double checked all connections.
Nick さんによる
