メインコンテンツにスキップ
The Infinix Hot 10i is an entry level smartphone with a 6.52 screen and a 6000 mAh battery released May, 2021.
52回答 すべてを表示
Touch Screen is automatically Working?
When I start using my phone after sometimes it's touch starts working itself and I press power button and then it works well for a few minutes.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 13
コメントを追加
4件の回答
最も参考になった回答
Hello @bshhanaesharama,
It seems like a problem with the digitizer, but I could be wrong. Most likely, the fix is to replace the display panel.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
@bshhanaesharama this is called a "Ghost Touching" and originates from a failure between the digitizer and the rest of the screen. Use something like this video as your guide. Replacement screens are readily available and not to expensive. Just do an online search and select a vendor that appeals to you.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
さんによる
Infinix hot 10 play automatically screen touch
さんによる
=== Update (11/16/23) ===
さんによる
さんによる
@ayanmohsin read my original answer. Ghost Touch on your screen too.
さんによる
1以上のコメントを表示
コメントを追加
Well I think you are facing the issue of ghost touch on android issue on your device well this video might be helpful for you:
https://www.youtube.com/watch?v=7goCFKzv...
And also check out this blog as well for more solution to your problem: https://wethegeek.com/ghost-touch-issue-...
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Screen automatically wark
さんによる
@infinixhot11s, read @oldturkey03's answer; you probably need a new screen if you're having the same problem as the others here.
さんによる
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
बिष्णु शर्मा さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 33
過去 30 日: 110
今までの合計 1,882
