メインコンテンツにスキップ
対象のモデルはA1419 / EMC 2806 / Late 2014 または Mid 2015。 3.3 または 3.5GHz Core i5 または 4.0GHz Core i7 (機種ID iMac15,1)、EMC 2834 late 2015 / 3.3 または 3.5 GHz Core i5 または 4.0 GHz Core i7 (機種ID iMac17,1)のRetina 5Kディスプレイを搭載したすべて。
573回答 すべてを表示
Logicboard & Display Swap iMac 2014 A1419 EMC 2806
Hey Guys,
I just wanted to ask if there is a chance I can swap the logicboard in my iMac 2014 A1419 EMC 2806 with a newer one and with that the display that fits the new logicboard.
What would be newest logicboard and display I could install? Which logicboard has upgradable RAM?
Thank you all very much in advance!
-Maxim
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Swapping the logic board in an iMac can be a complex task, and it's important to note that the compatibility of different logic boards and displays can be limited by factors such as form factor, connectors, and firmware compatibility. While it may be possible to upgrade certain components, it is generally not recommended or supported by Apple.
The iMac 2014 A1419 EMC 2806 model is part of the iMac "Core i5" 3.5 27-Inch (Retina 5K, Late 2014) series. It features a soldered GPU and uses a custom form factor logic board. As a result, it is not straightforward to swap the logic board with a newer one from a different iMac model.
Additionally, the display panel in an iMac is typically integrated with the logic board, making it difficult to swap the display separately. It's not designed as a modular component.
Regarding upgradable RAM, the iMac 2014 A1419 EMC 2806 model supports up to 32GB of RAM, but the RAM is not user-upgradable. The RAM modules are soldered onto the logic board, so they cannot be easily replaced or upgraded.
If you're interested in upgrading your iMac, I would recommend considering other options such as adding external storage, upgrading to a solid-state drive (SSD) if you haven't already, or connecting an external monitor if you need a larger or higher-resolution display.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Almost everything in this comment is incorrect. It looks like it's written by chatGPT.
- All logic boards are "custom", this does not impact whether or not they can be swapped
- iMac screens are not "integrated" with their logic board (the way an iPhone might be, through parts pairing)
- The RAM is not soldered to the board.
さんによる
コメントを追加
回答を追加する
Maxim Fetisov さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 34
