Cruise control doesn't work anymore, replaced brake module still doesn
Cruise control stopped working, replaced control module on brake pedal still doesn't work, fuses are good
Here's a link that may help.
Scroll down and click on the Cruise Control link.
It describes how to test the cruise control function
It is a bit tricky getting the document to load, but if you persevere it will open.
You may have to refresh the webpage page a few times (even after passing the security check, press F5 if using Windows OS) but it does work.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 37
