メインコンテンツにスキップ
Appleの主要モデルである2021年のiPhoneは、9月24日に発売され、6.1インチの有機ELディスプレイ、デュアル12MPカメラシステムを搭載し、5色のカラーバリエーションが用意されています。iPhone 12の後継モデルです。
89回答 すべてを表示
Why does a big yellow spot appear on my screen, even when it's off?
There is a big yellow spot (1cm diameter) when a green "halo" or gradient around it, that appears on my screen.
It is especially visible when the screen is off.
What would be a cause of this?
Below a photo of the screen when it's off:
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
Would be very helpful if you could provide some photos. With the screen off as well as on and how it looks over different things.
Permanent burn-in can affect a screen if you had a yellow spot on the screen and the brightness up to the highest, you could have permanently caused a "burn-in" where that stark part of the image is partially or fully forced into the pixels. Alternatively, a physical burn can cause spots on an LCD. Such as a lighter flame or an overheated chip on the logic board.
EDIT: Thank you for providing a photo.
That definitely looks like a physical burn. That section of the screen has nothing really behind it that should generate excess heat. The back of the screen is just a plate covering data cables, and inside the phone case is where the microphone is located and really not much else under that spot.
My money is on external burn such as you set it on the counter and it accidentally touched a corner of the hot stovetop, or got it too close to a lighter or something.
The good news is this kind of burn is basically cosmetic only, so as long as it's not big enough or obtrusive enough to prevent you from using your phone, you're just fine to use it as is. The bad news is if you want to fix it, it will require a screen replacement, which is quite expensive on the high-def screen of an iPhone 13. (For reference, $375 in my shop for OEM grade OLED screen, or $210 for an In-Cell LCD. I would wager prices at a shop local to you are roughly the same if using equal quality parts.)
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
@erelectronics just a quick heads-up. One of your question has been moved to Meta Check on here https://meta.ifixit.com/Answers/View/199...
さんによる
@oldturkey03 Thank you! I am still newish to using these forums and did not mean to post in the wrong place.
さんによる
@erelectronics there is never a wrong place. It's just "over there" where you catch the iFixit people :-)
さんによる
コメントを追加
Hello @alex12a,
has this phone been repaired recently?
If yes, i would assume that the display has not been positioned well and there is some pressure below that spot. In this case the display has to be removed and put in properly.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
この回答は他の質問に帰属しています。
@alex22254662 this looks to be caused by high temperature. Has the phone recently been exposed to high temperature in that area? Probably the LCD driver (the chip in the display) has gotten super hot or another component got fried. Id expect to see strange effects like screen going black all of a sudden, screen showing strange color bars, etc. start to happen soon (if not already happening).
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alex12a さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 7
今までの合計 66
