メインコンテンツにスキップ
これらの交換部品ガイドを使って、Samsung Galaxy Watch Active2を修理しましょう。
20回答 すべてを表示
Watch is charging but won't turn on after water damage repair.
I took apart my Galaxy Watch Active2, disconnected the battery and cleaned the inside with isopropyl alcohol after it was stuck in a boot loop from what I assume was water damage. After putting it back together and putting it on the charger, it shows that it's charging but won't turn on when I press and hold the power button.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@jackhardacre just because it says it's charging it might not be. Replacing a battery after water damage is almost always a must do. Of course, double check your work too and make sure everything is connected as should. Ultimately, it could also originate from the water damage having created a short circuit somewhere on the board.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jack Hardacre さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 293
