I can't install windows 10 with usb
There is a big problem faces me
I need to install windows 10 with usb
I press f12 to do boot
Then selected usb and press
Labtob restarted then nothing
I need to solve the problem
Thanks alot for everything
Hi @damynltfy,
Is the USB bootable, as you didn't mention if it was or not?
If not, here's how to create a bootable USB so that the Windows ISO can be loaded onto it and then you should be able to boot from the USB
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 84
