メインコンテンツにスキップ
This CD Player FM AM Radio system is now in its fourth generation of production. Originally introduced in 1984 (Radio only model, Acoustic Wave Music System). A model with a CD player was added in 1992. Earlier model depicted in photo.
8回答 すべてを表示
No power after circuit board replacement
We recently replaced the circuit board on our Bose AWRCC1 because the CD was skipping and freezing. When we connected everything again, it does not power on. Is there something that we need to "reset" in order for the unit to turn back on? Thanks for any help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@schnauzermom you should not have to any reset to have it powered up. Check your work to make sure that everything is properly connected. I would try the old board and see if this is caused by the replacement. If it comes on with the old one,but not the new one, you know that it is the board that is faulty. Let us know whcih board you had and which one your repalced it with. Post images of both so we can see if there are obvious things wrong. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
schnauzer mom さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 22
今までの合計 202
