メインコンテンツにスキップ
Released in May of 2020, Model Numbers: SM-A217F/DS (Global), SM-A217F/DSN (Russia), Processor: Exynos 850, 3GB/4GB RAM, 6,5" inches display, 5000 mAh battery with 15W fast charging and USB type C.
20回答 すべてを表示
Why is my phone restartng it's self at all times!
It restarts its self everytime when I use it, especially when I press the recent button
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
@solulelenc52780 the first hing I'd try is to start it in Safe mode to rule out any faulty apps etc. If it functions properly in safe mode you know that it is one of your apps that is causing this.
Next you could try recovery mode and see if that resolves any software issue. If that does not work try download mode and see if an update resolves this. Use the information from here about how to get into the modes.
After that, I would strongly suggest a new battery since a faulty one can cause these symptoms as well. iFixit does not yet have any guides but use these guides to work on your phone.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i want to factory data reset but not resetting, it appears about my email to verify if it me. verification has been done not factory data resetting
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Solulele Nchayichibi さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 77
