メインコンテンツにスキップ
2022年10月に発売されたGoogleのスマートフォン「Pixel 7 Pro」の修理・分解情報です。モデル番号はGP4BCとGE2AEで識別できます。
100回答 すべてを表示
Bent Frame Replacement guide
Does anyone have a good guide for a Frame replacement? I bent the phone in a car door. everything works fine and all internals are good after testing with a new screen.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Burke,
Yeah, that's the problem with having to fix a new model phone; the parts are expensive and information can be in short supply. However, the good news is there are other sites in the world that also support iFixit's repair philosophy; one such is a Spanish site called Nadie Me Llama Gallina. Their tutorials are well done and they do have just the one you're looking for.
Manuals / Google Pixel 7 Pro / Back cover with components
Of course, should you feel ambitious and altruistic, you'd have the gratitude of a lot of people if you were to document your repair and create your own iFixit guide. You can use existing guides as prerequisites and build on them with the steps needed to gut the chassis.
Good luck; let us know how it goes for you! Success stories are always appreciated, and we can usually learn something when things don't go right.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
CLOSE, That has to be the best page ive seen so far. they just did the side buttons which is awesome. but there are still components left. there are connectors on that remaining camera bezel they left in, along with the nfc reader.
さんによる
I need those too, but I really appreciate the tip!!!!
さんによる
@burke76365 That's the exact same situation I found myself in when I went to do the same operation on an iPhone X. Lots of guides but none that were complete; they didn't remove everything, apparently assuming replacements came with some parts already installed. I ended up writing a lot of guides for the iPhone X in order to be complete.
Your next best option might be to do a YouTube search for either rear case replacements or teardown videos.
さんによる
@burke76365 I did run across an interesting replacement part; it's in black though, so I don't know if that's the right one for you, but it has all the parts you're concerned with already installed.
Plus I see it has all the glass as well; the other ones I saw didn't even have that.
https://www.ebay.com/itm/364283551055
You can get the correct color in that same style from this website, but be warned, it's substantially more expensive than the one I just posted.
https://www.mobilesentrix.com/replacemen...
さんによる
コメントを追加
回答を追加する
Burke さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 20
今までの合計 362
