メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
AppleのM1 SoCとXDR mini-LEDディスプレイを搭載した第5世代12.9インチiPad Proの修理・分解情報です。2021年5月発売。
iPad Pro 5th Generation won't boot black screen, limited amperage draw
The iPad suffered impact that shattered screen. The amperage draw is continually .48, far below normal, regardless of how long it has been left on the charger. The charging port has been replaced and tested with no change. The screen has been replaced as well. The screen is black and there is no evidence it ever boots. Have tried soft reset (vol up, vol down, power). No change. New MFI cables and chargers have been tried. It will not mount for wipe/restore. Does not appear visible to external devices.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Did the device function before the screen repair?
I know the iPad pros need a lot of juice to charge. Have you tried any fast chargers?
Did you disconnect the battery while replacing the screen? If so, double check to make sure you have the battery screw securely in place. If you didn't disconnect the battery, you might've caused damaged to the board. Or if you pried between the battery connector you could've damaged that as well.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
No, the customer brought it to me functioning this way. It's currently on a fast charger, but hasn't changed in symptom.
さんによる 共有
コメントを追加
回答を追加する
jparks さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 10
今までの合計 404
