Keyboard only works when I put pressure between the keyboard/touch pad
The keyboard and touch pad quit working sometime ago, I found that if I push down on the case between the two they both work for a short period of time. Unfortunately doing this so much the case between the two is now somewhat bent down a little, I don't know if that is a big deal or just a cosmetic issue. Does anyone know if it is the keyboard that needs replaced or what, since it affects the touch pad as well. It still works putting pressure like I said but with it bent, I would like to fix the whole problem.
この質問は役に立ちましたか?
