Computer doesn't recognize my iPod classic 7th gen. why? What should I
My computer doesn't recognized my ipod classic 7th gen. Why? What should I do?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@molina671169627 couple of things you want to check. First is of course teh cable. Make sure it works and has no corroded or bend contacts etc. Next try a different USB port on your computer and lastly your iPod battery has to have enough power for the iPod to turn on to be recognized by your computer. Let us know if this ia a Mac or Windows computer.
このアンサーは役に立ちましたか?
@oldturkey I have tried 3 different USB cables and 3 different ports and it does make that sound the computer does when you connect something but that's it. My computer is windows. Although, the battery is a little bit more than half full and that hasn't been a problem before, I'm going to charge it full and try again. Let's see....
@molina671169627 so you get the Device Connect sound. That means your computer knows something got plugged in (your iPod was detected) we'll have to see if something in the permission has changed or if this is an iTunes issue. See if your iPod shows up in Windows Explorer
過去 24時間: 1
過去 7 日: 12
過去 30 日: 61
今までの合計 769
4 件のコメント
are you using itunes?
is there custom software installed?
timtom77 さんによる
@molina671169627 has it ever been recognized by this computer? Is there a possibility that it is a Mac formatted iPod on a Windows computer or vice versa? what have you checked and what have you tried?
oldturkey03 さんによる
Yes, I'm using iTunes. It's been always recognized by this computer until today.
molina6711 Molina さんによる
@molina671169627 Do to have a separate cable you can test?
Duck さんによる
