メインコンテンツにスキップ
Asus ROG 15'' ryzen-powered laptop released early 2021.
13回答 すべてを表示
I've tried adding a RAM upgrade to the single slot, and it never works
I've tried upgrading the 8GB single slot to 16GB single slot, and it never works and the computer keeps bricking - I know there is 8GB soldered on, but I've read you can upgrade the single slot, but it's not working at all.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Interesting. I would check the manual or online to make sure that the speed/capacity of the ram is correct for the slot and mobo inside of the laptop. In the past, I have had similar problems with other computers because I went above the maximum supported ram for the computer.
If that does not work/the ram is the correct spec, I would try a different stick of ram and see if that works. Your ram stick may be bad and that may be causing the computer not to boot.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Douglas Parrish さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 20
今までの合計 354
