メインコンテンツにスキップ
モデル番号 A1213/ 8, 16, 32 GB容量
216回答 すべてを表示
iPod won't hold a charge even AFTER replacing battery
After 2 years, my iPod stopped holding a charge. I would plug it in and after a couple seconds i would get the red battery icon saying the battery was low,but with the plug over it indicating that charging was complete. Sometimes it would show it was charging and the indicator would go green, so I would leave it. But when I came back to it the battery had drained instead. I just replaced the battery on it figuring that it was the culprit and was ecstatic when it charged right up, but after I synched it it was back to it's old shenanigans. Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
The batteries in most iPods have a ground strap that grounds the battery to the iPod's case. If you don't install this or do it incorrectly, the battery will not retain a charge
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Did you mean "will *not* retain a charge"?
さんによる
yes, sorry
さんによる
コメントを追加
I don't know about a ground strap. It had a ground wire that soldered into te board along with the pos and neg. I figured the connector might be the problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
hennemonger さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 3,409
