メインコンテンツにスキップ
This is the fourth generation Honda CR-V.
7回答 すべてを表示
How do I fix a 2013 honda crv window motor won't move
how do i fix a 2013 honda crv window motor wont go up or down i replaced the regulator and the cable for it and the fuses for it still nothing the switch itself works on the other side of for the other window yet it won't work for the right rear passenger window
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
@jamesmackin here is how to check it
On the power window master switch connector Connect terminals No. 18 (or No. 17) and No. 20, and terminals No. 17 (or No. 18) and No. 16 with jumper wires.
Check right rear power window motor operation:
The right rear power window should close (or open).
Should that not work you know you have
  • Faulty right rear power window motor
  • Faulty right rear power window switch (You already ruled this out)
  • An open or high resistance in the wire
Here is how to check the motor
Since you already replaced the regulator etc. you probably do not need instructions on how to get into the door :-)
Update (04/24/23)
@jamesmackin so you checked the master switch connector and have no power for the read window? Or did you just check at the door? You will need to check at the main connector. Check the under the dash fuse panel. I believe that your windows each have an individual fuse #43 is for the rear passenger side power window.
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
No power at all on that side
さんによる
Would that be the one that goes across the middle of the car then up the side with a blue connector
さんによる
@jamesmackin that connector is the one on the driver side. Where all of the window switches plug into
さんによる
All the others had power but not the rear right window switch
さんによる
@jamesmackin did you check all of the points I gave in my answer? You applied the jumpers on the main connector and still have no power?
さんによる
1以上のコメントを表示
コメントを追加
Have you checked with a multimeter the continuity on the wires from the switch to their connection point? it could be getting cought on the flex between the door and the frame, you could also try swapping the switches around which will eliminate the switch or the wiring.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
There is no current at all
さんによる
コメントを追加
回答を追加する
James mackin さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 33
過去 30 日: 67
今までの合計 491
