Debbie Durham, I just checked the manual for your camera available here, and this is what it says" Memory card and internal memory full.
■ Transfer pictures to the computer (see page 37).
■ Delete pictures/videos (see page 14), or insert a new card"
You did not tell us if you are using a CF card to add room for more pictures. You can purchase an SD card to store more pictures and videos. You can copy pictures/videos from a card to internal memory or from internal memory to a card. Before you copy, make sure that:
■ A card is inserted in the camera.
■ The camera’s image storage location is set to the location from which you are copying.
Copy pictures/videos:
1 Press the Review button, then the Menu button.
2 Press to highlight Copy, then press OK.
3 Press to highlight an option.
4 Press OK.
NOTE: Pictures/videos are copied, not moved. To remove pictures/videos from the original location after copying, delete them. Hope this helps, good luck
7 件のコメント
my camer is doing the same thing Help
Maraian さんによる
any sd card I put in says the same thing internal memory full
john keimel さんによる
I get this error with 64GB card but works fine with 32GB card.
orcshamen さんによる
Try going to your setup icon, scroll down until you see the image storage. Set from internal memory to auto. that should help
Paul yates さんによる
To orcshamen - error with 64GB but not with 32GB memory card.
You can check what memory cards are compatible with your camera.
Go to MEMORYCOW the memory card supplier how provide the facility to check which memory cards are compatible with any camera.
Jim Vice さんによる
2件以上のコメントを表示
