メインコンテンツにスキップ
S20シリーズのGalaxy Sスマートフォン。AI搭載トリプルカメラ、Infinity Oディスプレイ、LTE、5G機能付きWiFi 6を搭載。新色6色で展開。
31回答 すべてを表示
Moisture detected warning hasn't gone away after days of trying to fix
Hi, I have been unable to charge my S20 FE using the cable for the past few days, and the moisture warning is always in my notifications menu. I have tried following:
  1. Cleaning out the charging port with alcohol and a toothbrush
  2. Trying 3 different cables
  3. Clearing USB cache
  4. Charging whilst phone is off (shows a moisture droplet)
  5. Charging in recovery mode
At this point should I try replace the charging port?
Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Yes, replace the port. I myself haven't figured out why this happens, but I see it at least a few times a month with a wide range of galaxy devices. Just make sure you order the port that corresponds with your model. If you order the wrong one, it will cause issues such as a "no sim" message. You can find the model number of your device by going into settings, scrolling down to about phone, and somewhere in there it'll give you the exact model number which is the letters "SM-" then usually 4 numbers and one or sometimes even two letters.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I assume this will work for your phone as well...
Worked on a Samsung SM-T510 tablet, came in with moisture warning symbol and wouldn't charge,. So i replaced the port with the correct replacement and still the warning appeared. Now here's the weird part.. when the tablet is in download mode or in factory reset mode the battery will charge with no issues, power on the device to home screen, plug in charger with no issues.. this moisture symbol warning only appears when the battery has been depleted. So the trick is not to let the battery die, but if you do, you will have to charge in download mode for 20mins or so then power on device and plug back in to to full charge.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
JJ Roberts-White さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 39
過去 30 日: 112
今までの合計 1,962
