メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
元々はBeats Studio Wirelessとして知られていましたが、しばしばBeats Studio 2 Wirelessと呼ばれます。軽量化、高耐久化、快適性の向上を図り、有線接続の第2世代Beats Studioと共に2013年に発売されました。初代Beats Studioの後継機種です。
Headphones won't charge nor turn on - battery already replaced
Hi all,
I bought used Headphones and fixed them myself. Now after 3 years of usage without problems, my beats began to act weird. Some weeks ago when I wanted to use them, they went out of power. Discharging itself while turned off. So I charged it and it works for some hours. Some days later again, empty without using them. Since last week no sign of life. I bought a new battery, replaced the old one, plugged the charging usb cable but no charge indicator. I tried the 2 min's reset button combo 3 times, but nothing happened.
I checked all power sources and cables. Everything else charges fine, but not my beats...
I checked all solderings and cables but they are fine too. Is maybe my motherboard dead?
I also checked the USB Port on the beats. No sign of damage, or wobbly cable. Cable sits nice and tight.
Usually a new battery is not completely empty. It should turn on right after plugging the battery, but nothing.. any idea?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi
It sounds like you have a bad main board unfortunately
If you really wanted you could try and fault find the bad component with a Multimetre to you could replace the main board
Here’s a guide for getting the board out
https://www.youtube.com/watch?v=NRnIeZqk...
If replacing this board doesn’t help it could be a issue with the Bluetooth board
Heres a guide for that too
https://www.youtube.com/watch?v=YSLjEneZ...
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
For me it was the Power Circuit board. Replaced it with a chinese ali express part. Now it works
さんによる
コメントを追加
回答を追加する
Ifixstuff さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 20
今までの合計 509
