メインコンテンツにスキップ
Appleの主要モデルである2021年のiPhoneは、9月24日に発売され、6.1インチの有機ELディスプレイ、デュアル12MPカメラシステムを搭載し、5色のカラーバリエーションが用意されています。iPhone 12の後継モデルです。
50回答 すべてを表示
Why wont my Wifi and bluetooth turn on?
So recently my phone has been doing this thing where it will not let me turn on wifi or bluetooth.
I've tried everything i could think of, and i even searched google to find answers but none of them worked.
I've tried:
Shutting off my phone, and turning it on again.
Tried to turn it on by dragging down from the top corner to the right.
I read somewhere that I could try and reset my network settings, but if i go into reset on settings, it wont show me all the options of reseting, it just says "reset"
Updating my phone.
Turning airplane mode on and off several times in a row.
None of them worked, and im really annoyed.
Can someone please help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
The flow for resetting your network settings is a bit different on iOS 16. You may need to click reset first and then a host of reset options will appear. It will ask you to confirm before it does anything and warn you if you are about to erase any data. The How to Reset Network Settings guide has some pictures/screenshots.
Otherwise. I might have a look at the iPhone Won't Connect to WiFi troubleshooting page. There is a Bluetooth one as well, but many of the steps are the same since the technology is similar and is handled by the same chip on the iPhone logic board.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
I’m Tanja :0 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 17
今までの合計 42
