メインコンテンツにスキップ
2013年11月22日に発売されたMicrosoftの第三世代のXbox ゲームコンソールです。
694回答 すべてを表示
My xbox one wont turn on
one day i went to turn on my Xbox and it didn't turn on i took it apart as i have done before to others without much issue, i looked at the parts everything seemed fine i put it back together turned on once i turned it off waited an hour tried turning it back on and it would play the sound to signal it had power running to the console and it was turning on but the light would go out and the console wouldn't turn on, meanwhile on the power brick the light was solid orange until i pressed the button then it would temporarily go green before turning off then going back to orange
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
There is a good chance you have a power supply problem. There is a troubleshooting guide here that contains the power supply guide in it. Xbox One Won't Turn On Best of luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
just some music guy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 22
