メインコンテンツにスキップ
Repair and disassembly information for Samsung's Galaxy A13 Android smartphone, released in March of 2022.
84回答 すべてを表示
Why is my screen touching itself
Keeps touching itself
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
screen touching not waking...
さんによる
コメントを追加
3件の回答
最も参考になった回答
Hi Mathew,
"Ghost touches" as the problem you're having is described, is a result of the phone's processor getting bad data from the digitizer, or touch screen. It's usually a result of a damaged touch screen, as there are delicate connections between the flex cable that goes to the logic board and the glass on which the digitizer circuitry is printed. The glass does not have to be cracked for the touch screen to fail; it's frequently the case that no damage is visible at all.
It is possible for the problem to be located on the motherboard, but since those issues are generally not repairable by us normal home DIY-ers, let's stick to the part we can fix, the screen.
The best chance you have to fix this yourself is to replace the screen, but there are certainly things you can do to try and diagnose the problem before you go ahead and order a replacement screen. Unfortunately you'll have to open up the phone to check those things out. You can disconnect the screen connector, clean it with 90% or higher isopropyl alcohol and reseat it firmly. If that doesn't help, then it's probably time to replace the screen. For that some instructions would be nice; unfortunately iFixit doesn't have a guide for you, but there's a German site called iDoc that does.
Samsung Galaxy A13 screen replacement - repair guide
Good luck; let us know what you find!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I was having this exact problem. Tried everything, even got a new phone. But when the new phone died I dug the old a13 out and accidentally figured out that for some reason the ghost touch problem goes away when the phone is charging. No idea why. Probably not good for the battery to constantly be plugged in. And it's certainly not convenient during times where I'm not near a charger. But as an immediate solution until I can get a better phone plugging it in solves the problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
When I'm watching to titok it touches itself
When I'm on WhatsApp it freezes sometimes
Facebook too likes itself sometimes
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mathew Kibii さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 38
過去 30 日: 160
今までの合計 1,211
