メインコンテンツにスキップ
A smartphone, running Android, released in November 2018. Featuring a 6.21" edge-to-edge glass display and plastic body. Models include: HRY-LX1; HRY-LX1MEB; HRY-LX2; HRY-AL00a; HRY-AL00; HRY-TL00.
12回答 すべてを表示
Why won't my phone work after falling in water
can my phone be fixed after falling in water 2 years ago and it has not been able to turn on?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
After 2 years you'd be very lucky. New screen, new battery, possible unrepairable corrosion on the motherboard. Nothing to stop you having a go. Ideally you'll need a microscope, hot air station. Isopropyl alcohol and a toothbrush. Start with removing the board, remove any shields and clean any corrosion, as best you can anyway. Replace the board and try charging it. All depends on what is was damaged with, toilet water, sink water etc. I have a iphone se in a similar state. Just need the energy to strip the board out lol.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Thanks Nigel, I agree that it will be highly unlikely to fix, but I can only try lol.
さんによる
@Aut you can only try, hopefully you'll succeed. Good luck with it.
さんによる
コメントを追加
try cleaning the board with alchole this should remove some of the corrosion on the board
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Aut さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 117
