No current going to the ignition coil
I ain’t get power to the plug that connects to the ignition coil my truck is a crank no start
Hi,
Here's the 1998 Ram Truck 1500/2500/3500 Service Manual + Wiring Diagrams
Scroll down and click on Electrical > Ignition system to view how to check the ignition. If this section fails to load, press F5 (if Windows OS) to reload the page.
このアンサーは役に立ちましたか?
Check your distributor
このアンサーは役に立ちましたか?
I figured out the current add relay was bad now the coil ain’t sending spark to the distributor I put a spark tester and it ain’t doing nothing
過去 24時間: 3
過去 7 日: 4
過去 30 日: 9
今までの合計 151
2 件のコメント
Hi, What is the year and engine size of the vehicle?
jayeff さんによる
1998 5.9 gas
Jacob Fisk さんによる
