Why won’t my reverse lights work?
My reverse lights won’t work
Iv brought it to mechanics and they have checked everything
Is there anything else they could be missing or is there any well known problems with head lights in Audis
Mechanics are not the place to take it when you have an electrical issue. You need to take it to an auto electrician to diagnose properly. Yes, they charge more per hour, but they will fix the problem. Yes, there was a common problem with dry joints and relays requiring cleaning inside the Body Control Modules, but will need you to confirm Model, engine size and Year to see if it relates to your vehicle.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 4
過去 30 日: 16
今までの合計 319
2 件のコメント
Hi Kayleigh,
What year is your A3? Is there any relevant submodel information that would help us look up a wiring diagram for your car so we can see if we can help? Is it an automatic or a manual transmission?
Jerry Wheeler さんによる
Hi @kayleighcliff22
Reversing lights or headlights, as you mentioned both?
jayeff さんによる
