Transmission has no up shift
No up shift from second gear
Is it an automatic? Most likely it's the Auto Trans Computer. A common problem throughout the 1990's built models. I've personally repaired thousands. Problem often starts with electrolytic capacitors and you can smell it. Leaking / exploding ones often pop the uP chip. Can also be the sensor, but you will need to measure to see if it's switching.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 157
Hi,
What is the year model of the vehicle?
jayeff さんによる
