always in low power charging. and won't read USB or comp
Always says charging in low power mode and can't read USB or computer
Brt Jensen by this "can't read USB or computer" do you mean it doesn't get recognized. That would be an issue with your charging port. Check for bend or corroded pins. If nothing else, you may have to replace it. It is soldered to the board so a total dismantle would be in order. Something like this should work for yours as well.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 118
