replacing the internal HD
Can I replace the internal HD for a SATA2 disk?
Or it must be a SATA disk? Any SATA disk?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You're lucky as your machine does not require the new Apple firmware hard drives with temperature sensors. Any SATA 3.5" hard drive should work for you. The newer drives may need to be jumper down to 1.5 Ghz to be seen and formatted. Just do a web search for your drive and jumpers to get the correct setting.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 273
1件のコメント
I just replaced my hard disk a couple of days ago and I'm with a 'new' computer; things now are fast and reliable.
The replacement procedure is a very easy task.
sergio barrozo さんによる
