メインコンテンツにスキップ
General repair information on LG washing machines.
12回答 すべてを表示
Only works on Speed Wash
My LG front load washer (Model : WM2501HVA) when trying to run a normal load the machine will fill with water, start the wash cycle and when it’s time to drain the water, the panel flashes the error message FE. The only way to get the water the drain is turn the machine off and change to a “Speed Wash”. I have checked the lines and filters for any blockages, I have even ran a cycle with vinegar in hopes of clearing out any buildup. The only cycle that works is the “Speed Wash” but the problem with that is my clothes do not smell clean with just one wash and that’s not cost effective having to wash each load twice. Please help can’t afford to keep doing this or spend $100’s on a repair man.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
この回答は他の質問に帰属しています。
Hi @annabelle66
An FE error code means that there's a problem with the water level in the machine.
Here's the service manual that may help as it describes how to run the diagnostics and test the water level "frequency" i.e. the level of the water in the tub - see p.19
Here is an explanation of what to do to check what the problem is regarding an FE code.
Here's the parts diagram for a section of the washer that show roughly where the water level pressure hose (aka black air hose as mentioned in the explanation) is located in the washer - see part #K550 lower right of diagram.
Even though it was mentioned that the water level pressure switch never fails here's the parts diagram showing the location of the switch in the Cabinet and Control panel and what it looks like - part #A410
If the switch is faulty (how to test is described in explanation) search online for 6601ER1006E to find suppliers that suit you best.
Hopefully this is of some help.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Anne さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 38
今までの合計 66
