Why don't my ps4 accept any update? It gives me two errors
It gives me two errors. Cannot access system storage and update file is corrupted.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Try a different hard drive and/or redownload the update. If you're going for current firmware and can connect the PS4 to your network via LAN cable, you can also try the safe mode option and skip having to download/use USB.
このアンサーは役に立ちましたか?
I tried re-downloading the file many times. I changed the hdd into another one. Both are 100%. Changed the USB. Still getting the same errors. Even I tried both USB Ports.
You mentioned errors, can you share the exact code?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 31
