メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1233回答 すべてを表示
2 battries in and still wont turn on
Hello all!
Iphone 5c model #A1532
Got 2 batteries off of amazon thpught the first one was bad out of the box because it shows a charge of 0.7A and immediatly drops to 0 then back to 0.7A it just repeats this cycle endlessly. Also wont turn on the screen or anything else. I dont have the hardware to test if the battery has charge or not and I also dont have the hardware to check the screen too ensure its not damaged or anything.
Initial problem was the phone would not stay on and also would not boot once battery charged I got it a couple of times enough to back it up but became unreliable.
Figured a new battery would fix it but maybe the Motherboard is dying?
Ill ship it to someone if they want to play with it otherwise comments and suggestions are welcome.
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
connect to a pc to check if it connects, if not try with only the screen, battery and port connected to rule out other part issues, if none of these work its probably a board issue. if your in the uk i could take a look for you if you like
さんによる
Ya it doesnt power up at all. But I fugured that's because the battery doesnt work? It acts like the battery isnt even in there. Should it still connect to a PC even with no battery? I have tried connecting ut before and got nothing from it.
I can still send it to you in the UK I dont mind.
さんによる
コメントを追加
2件の回答
最も参考になった回答
@p38sheep - Ebay, Amazon, etc are known for VERY VERY Questionable batteries!
iFixit On the other hand has reputable Parts&guides.
As @tech_ni said If it shows up on a PC We can rule out the other issues...
Honestly I bet it was that it was an amazon battery.
Part: iPhone 5c Battery
Guide: iPhone 5cのバッテリーの交換
P.S I would be willing to play around with it If you ship it to me or your not willing to fix it
iPhone 5c Batteryの画像
製品
iPhone 5c Battery
$29.99
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
i would also add mobile sentrix and injured gadgets as purveyors of quality batteries
さんによる
I love more resources thanks for adding this!
さんによる
@beekerc - Yes! Thanks for the Info! :-)
さんによる
コメントを追加
It does sound like a motherboard issue to me personally, but if you can get it to appear on a computer like Ben said then you can rule out that for the most part.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Reputable made me giggle, loads of quality batteries for sale on eBay if you know where to look.
さんによる
コメントを追加
回答を追加する
P38sheep さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 68
