メインコンテンツにスキップ
Repair guides and support for computer monitors produced by Samsung.
77回答 すべてを表示
Color is wrong, but still works sometimes
The screen fell face down and it seems like it can't display dark color properly. But sometimes, it would turns back to normal. Perhaps the impact has made a cable inside the screen loose? Forgive me my poor english and amateur skills.
Here are some information about the monitor:
- 20 inches
- SyncMaster B2030
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント
What is the exact model number of your monitor? We need this in order to help you.
さんによる
more infos have been provided in the edit
さんによる
It may just be a loose connection. I would open it up and disconnect and reconnect all the connectors.
さんによる
@thequacker Yes I think the issues are in the connectors, but it would be nice to have a tutorial on how to open it.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Cao Do use something like this video as well as this one You should definitely get you into your display. Concern I have are the vertical stripes on your monitor, which are usually caused by the ribbon cables on top of the LCD having come loose. Once you have it apart, heck all the LVDS cables (not the once to the panel, those are fixed and can't be removed) and make sure that they are properly seated and have no corrosion or tears on them.
Cao Do it would be great if you could create a guide when you work on your monitor. It would really help the next person that has issues with their Syncmaster display. It's fairly easy and fun to create. Just take lots of pictures. No worries about language etc. since you have lots of people on here that are always willing to help out with that.
https://www.ifixit.com/Guide/new
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Cao Do さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 31
