メインコンテンツにスキップ
Screen backlight won't turn off?
I have a rather strange problem. I recently replaced my screen but in the process must have damaged something as the backlight began to flicker. I then replaced the display cable and the isight cable (which includes the power cable). This did not resolve the issue. Finally, I replaced the LED display driver board and now, the backlight will not turn off. Ever. As soon as there is a power source (power or battery) the backlight turns on, even though the computer is turned off. When I boot the computer, it boots normally, with the screen functioning normally. When I power off, the backlight remains on.
I put my original faulty led driver board back in, and the backlight started flickering again. Put the new one in, the backlight won't turn off.
Did I just receive a dud driver board? It seems very strange that the screen always stays on, even though the computer is off. Any other possibilities?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
I would say yes that you received a faulty driver board. I'd put money on that, not my life. With the flickering problem on the original one and now the new one won't turn off there may be some other problem - on the logic board. On the Apple LED backlight system the voltage for the backlight goes up the LVDS cable and the driver board acts as a switch to give the LEDs that voltage. The driver board amounts to a 5 volt switch. I'd return the driver board for an exchange or refund.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks, I was afraid of that. After 2 screen replacements, 2 cable replacements and now what will be 2 driver board replacements I'm starting to get tired of patching up this macbook pro. Maybe time to bite the bullet and buy a new one :(
さんによる
コメントを追加
回答を追加する
Ben さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 914
