メインコンテンツにスキップ
2.3GHz, 2.6GHz, or 2.7GHzクアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大3.7GHz) 6MB 共有L3 キャッシュ付き。
561回答 すべてを表示
Very loud fan after battery replacement in MacBook Pro (Retina, 2012)
I replaced the battery (see bow link) for my MacBook Pro (Retina, 2012). Everything is operating as normal except the fan loud and constant (even though it doesn't seem like the laptop is overheating), this never happened before the battery replacement. I reset the SMC but that didn't do anything. Any ideas?
BATTERY REPLACEMENT
Update (01/17/2023)
I restarted the system and held the D key, this is the error message I got
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Let’s see if the onboard diagnostics give us a clue on what’s happening. Restart the system and press the D key to enter let us know what the error message is.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I did this and got the following message, I've also attached a screenshot in original post:
Error: 0x8000000000000003, Cannot Load 'EFI/Drivers/TestSupport.efi'
Status: 0x00000003
さんによる
@dukesup1978 - Well I was hoping it would work !!😖!! Open your window and scream “thanks Apple for breaking it”
So… Plan B! You’ll need to get this app which will give us some detail TG-Pro you’ll need the full version to get the diags. Post a snapshot of the main screen make sure to capture all of the sensors.
さんによる
コメントを追加
回答を追加する
DUKE さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 51
