Monitor turns black and have horizontal lines on high refresh rate
Monitor: Acer XV240Y
The monitor was fine when first bought, the max it can run on original spec was 165hz but then slowly, the monitor appeared to have a weird horizontal glitching lines similar to this (refer to the link) MSI Optix MAG24C Horizontal Lines
I never did anything to the monitor before, it just starts getting more and more glitchier so I had to switch down to lower refresh rate which were 144HZ but then after some times the thing happend and I kept switching down till 85HZ which I am still at rn and it stopped at 85HZ. I've tried switching out the input cable from DP to HDMI and it still has the same problem, even when switching the power connector still has the same problem, and it's not the PC's fault aswell because I tried it with a laptop aswell and it was still the same so it has to be the monitor. I've asked so many people about it and they had no idea and the link above is the only one that I found that have a similar situation to me.
https://www.reddit.com/r/Monitors/commen... here's the video of how it used to look like when it first started out
1件のコメント
i have the same issue with my msi monitor... did u find a fix to it
shouni007 さんによる
