メインコンテンツにスキップ
ウォーターサーバーの修理と解体ガイド
84回答 すべてを表示
Why won't my bottom load water cooler pull water from the jug?
My bottom load water cooler won't pull and dispense water from the jug. We've tried another bottle and made sure the cap with water tube is securely inserted. What can I try to fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Hi @lauriehammell,
What is the make and model number of the water dispenser?
さんによる
@jayeff Model: 1237BHC/YL1237S. Not sure of the make. The machine doesn't say but when I search this number I see Primo and Avalon.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi @lauriehammell
Found the user manual but that's about all I could find. Not that it is much help when troubleshooting
Since it is a bottom load, there must be a pump to pump the water up to the dispenser.
If the pump seems to be operating when trying to dispense water, maybe check that there's no air locks in the feed from the bottle to the pump.
Otherwise I don't know unless there a problem with the control board. Try resetting the device by removing the power for 5-10 minutes and then reconnecting it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Laurie Hammell さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 22
過去 30 日: 77
今までの合計 128
