メインコンテンツにスキップ
The first generation Honda CRV, produced from 1995 to 2001.
95回答 すべてを表示
How to repair my shifter
My truck won't go into any gear unless i use the shift lock release button
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
選択されたソリューション
khalif, I think you should combine the two of the questions you are asking. I think there might just be a common connection. I would start with replacing the brake light switch. As you mentioned in your other question, your brake lights do not come on when depressed. If your brake light switch is malfunctioning, your brake lights will not work,nor will your gear shift locking mechanism. Check the wiring on the switch, makes sure it is adjusted right, and you can check it with a multimeter.Replace the switch, re-evaluate and let us know. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I replaced the brake light switch in my buddy's crv 2001 and still no brake lights? There on but don't Britten up when peddle is pressed no high mount light on though and replaced all bulbs and checked all fuses
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Did you check the switch to make sure that it is being activated when the pedal is depressed?
さんによる
Ya there is a white pin that pops out when peddle is pressed I replaced it and still nothing
さんによる
Replaced the switch sorry made it sound like I replaced the white pin the way I wrote that
さんによる
コメントを追加
回答を追加する
khalif さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 3,179
