xbox is scrolling down the page
I have the same problem yes it stops when unplugging controller and it also doesn't do it when I use the Xbox app
This might be a drift issue. Can you run a controller calibration test on it? I'm not sure about the Xbox One but you can hook up your controller to a PC and run a test here: https://gamepad-tester.com/
That will show you if the sticks are registering any input in the neutral position.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 19
