メインコンテンツにスキップ
Repair information and support for GE Profile Refrigerators.
127回答 すべてを表示
Why are moldy looking particles coming out of my water dispenser?
Ever since changing the filter nasty looking flakes and moldy looking flakes have been coming out of my water dispenser. GE is saying they need to send a tech out and before that I’d like to ask if anyone else has had this issue and see if there is a solution. Yes I’ve removed the faulty filter and replaced with the plug and have run vinegar thru the system multiple times with no success. Any advice is appreciated.
Update (07/08/23)
@jayeff.
I finally ordered and have replaced the cold water reservoir. Upon removal of old reservoir it was filled up with slime/mold. The new reservoir seems to be performing great with nothing other than water coming out.
Thank you again for the advice and parts source.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
Hi @yimmygee,
You said that the water filter was faulty, how was it faulty, wasn't it filtering the water?
Have you checked the quality of the water supply connected to the refrigerator?
If you've bypassed the filter with a bypass plug then there's nothing to stop the contaminants from entering if there is a problem with the supply e.g. old pipes perhaps.
Does the ice made in the refrigerator ice maker also have flakes etc in it?
What is the model number of the refrigerator?
さんによる
Hi @jayeff thank you for the reply. I should've taken a step back before posting my question.
The fridge model is: GFE28GSKKSS
Yes there are no odd flakes or moldy looking particles in the supply from any other faucet in the house.
I replaced the in fridge filter with a hydroviv remote filter and a new supply line.
There are no issues with the ice.
Thanks again for the advice.
さんによる
With my GE 'fridge, I have not had your problem. But when I have changed water filters, I did notice that when I dumped the water from the old water filter into my sink, black flakes came out of the old filter. The flakes looked like carbon to me, which I think is ok, because carbon is used to absorb impurities, smells, flavors. So all I'm saying is, it might not be mold.
I agree with Jayeff, there is a small water tank inside the fridge used to provide cold water from the dispenser. It may take some time to clear any black flakes from that tank.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi @yimmygee
I actually meant only the water supply outlet to the refrigerator, not the water supply in the premises in general, but since there's no problem with the ice then it's OK
Looking at the parts for your model, there is a cold water tank (part #WR17X27627) in the refrigerator, where the water is stored after it passes through the filter so that it is cooled down, so that cold water is available rather than water that is at the same temp as water straight from any faucet in the premises.
I realize that you said that you flushed the system multiple times but it still may be that the problem is emanating from there.
If you decide to check it out, here's a video that may help. If you decide to replace it, search online using the part number only (shown above) to find other suppliers that may suit you better.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thanks for this @jayeff , I'm going to check it all out. Is removung and cleaning the reservoir an option or replacement the only way?
さんによる
@yimmygee
You could try removing it and then cleaning as it may be easier to get a stronger water pressure flow through it when removed or even let it soak in a tub etc. and then flush.
Flush into a tub/bucket so that you can check if there is any mould etc coming out of the tank
If still no good then you may have to replace it.
Let us know how it goes?
さんによる
コメントを追加
回答を追加する
James さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 18
過去 30 日: 93
今までの合計 326
