メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
iPhone 4 Wifi Antena to Logic board screw nut.
I am looking to replace a missing nut that was hidden behind the Wi-fi antenna which connected to the logic board.
For nut is was connected to the screw marked yellow in Step 13 (iPhone4のディスプレイアセンブリの交換).
I've seen two posts regarding this but no solid leads on where i can purchase it. Ive contacted several resellers and they only offer the screws.
Thanks in advance
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
6件の回答
ベストアンサー
The yellow circle screw is possibly the smallest screw in the iPhone. Lack of this screw or the round serrated edge nut it goes into should not interfere with the iPhone function at all. I think the only function of this screw nut combination is to help hold down the cover shield, but is not necessary for any function I can see. If your iPhone has functional problems look elsewhere for the cause of the problem.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
The nut is without purpose IMHO. In every 3rd iPhone of my customers that nut is separated from the logic boards and their wifi is fine.
In my opinion it is a predetermined breaking point. If the iPhone fell down it will easily break off.
I guess when it is missing, Apple Technician can tell that somebody tampered with the iPhone already.
So if you are fixing an iPhone for a customer who still is under warranty, better put it inside there again after you are done. Just hold the nut with a tweezer while you tighten the screw.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It has something because I have this problem too... I broke this nut from logic board and my wifi is greyed out, and I have Mac adress of bluetooth,and IMEI, just wifi shows N/A
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
i have seen a lot of iphone 4 who work perfect without screw and nut
さんによる
コメントを追加
@Ciclajbek
did you every fixed the grayed out wifi problem on your phone?? because i can not figure out why my wifi is grayed out.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i've lost that nut too, and the wifi signal its very bad, ussualy being not available or just with 1 line maximum 2
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
on wifi antena on iphone 4 where does each screw go because i have 5 and they are diffrent sizes and im not sure wich one goes where please help asap thanks????
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
コメントを追加
回答を追加する
blkmagik73 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 3,232
