メインコンテンツにスキップ
AndroidベースのスマートフォンSamsungのGalaxy Aラインの修理ガイドならびにサポートページです。
3101回答 すべてを表示
Troca de frontal a03s / Change front of A03s
Como trocar frontal do A03s
Google translate: How to change front of A03s
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi @mcarlinhos,
As with most Samsung phones there are two ways to do this.
  1. LCD only
  2. LCD and frame
There are advantages and disadvantages to both methods. The first is slightly cheaper, as you are buying only the LCD without the frame, but generally the price difference isn't enough to make this a decisive choice.
Otherwise, it's a tradeoff between having to separate the old LCD from the frame and re-adhering the new screen vs. having to move virtually all of the components inside the phone to the new frame + LCD assembly. That's something you'll have to decide for yourself.
Here's a YouTube video showing the first method, replacing the LCD only.
Samsung Galaxy A03s LCD Replacement - YouTube
This video guide shows how to replace the entire frame and screen assembly.
Galaxy A03s (A037U) Screen Replacement
You can buy either version of the screen on most of the popular sites such as Amazon, eBay and AliExpress among others.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Display change
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@mukeshmeher, if you need to know how to replace the screen, then see my answer to this question, as it tells you everything you need to know.
If that's not the problem for you, then you'll need to give us a better description.
さんによる
コメントを追加
回答を追加する
CarlosCarvalho 123 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 83
