メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ホームおよびホームオフィスで使用するために設計されたHPラップトップの修理およびサポート情報。
Won't turn on
I have a hp pavilion gaming laptop 15-dk1056wm it won't turn on you can push the power button and it will turn green for about three or four seconds and then goes back out the keyboard does not light up the power button just turns off
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
if you have another monitor, connect it to that and tell us what happens
さんによる
I have hooked it up to my TV and still the same iv unhook the battery and held the power button in for a minute still nothing I even unhook the battery and plugged in the charger same thing iv done all the troubleshooting I know of
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi,
Will the laptop turn on with the charger connected?
Does it show that the battery in the laptop is charging when the charger is connected.
It it doesn't indicate that the battery is charging, when the charger is connected to the laptop, it may be a faulty charger or a faulty DC-In jack (example only to show part).
First check that the charger's output is 19.5V DC at the plug. If you haven't got a voltmeter, try connecting a known working, compatible charger to the laptop to see if it charges the battery. If it does allow it to fully charge the battery before attempting to turn the laptop on.
If the charger tests OK (or a compatible charger doesn't charge the battery either) open the laptop and check if the voltage from the charger appears at the motherboard connector, where the cable from the DC-In jack connects.
If there is no voltage there then the problem is in the jack and it will have to be replaced. Here's the maintenance and service guide for the laptop model series that may help. Go to p.51 to view the procedure to remove the power cable. Initially you won't have to remove it, just gain access so that you can test.
If it is determined that the jack is faulty search online for L56904-001 to find suppliers that suit you best.
If it indicates that the battery is charging when the charger is connected, but the laptop still won't turn on and since you've tried a power refresh there's a motherboard problem which will have to be further investigated.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
jughade84 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 289
