Mid 2009 モデル番号A1278 / 2.26、2.53 GHz Core 2 DuoプロセッサーEMC 2326
868の回答 すべて表示
broken tap of battray light
i open my macbook pro but after above battray tap light of battray broken
Update
sir , i open backside macbook pro ,i would repair my macbook pro but i cut tach battry(light) to mother board ... and now my macbook pro is turn off
please help me..
dear.....
Update
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
I don't understand your question, please get some help with your English or use something like this translation program: http://translate.google.com/
による
I am not understanding what - tach battery(light) is. Could you please take a picture of what has been severed? Why did you open the case of the laptop to begin with? What country are you from? Please feel free to reply to this in your native language - I'll get the interpreter. It is best if you are expressing your thoughts in a language you are familiar with.
による
please help me..
dear.....
による
where are u . why u answer me
による
Because no one can understand your question. Two of us have stated so and you chose to ignore our requests. Please get some help with your English or use something like this translation program: http://translate.google.com/ Or state the question in your own language.
による
表示する 3 他のコメントを
コメントを追加
Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
当社のショップを閲覧する
3回答
選択されたソリューション
This not the battery cable. Seems to be a broken trackpad cable or backlight keyboard cable. The broken connector matches the socket at the right of the battery connector. It looks like the battery connector is still there but is now hidden under the battery socket.
Now the question is: why the MBP does not power on ? Maybe the cable was broken while the machine was powered and a short damaged the logic board ? It's all speculations since we don't really understand the question.
この回答は役に立ちましたか?
スコア 2
コメントを追加
this is my problem
この回答は役に立ちましたか?
スコア 0
コメントを追加
please help me ,i need my computer (macbook pro)
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
hamidbacr さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 259
