The Hisense 32H4C model is a 32-inch high-definition television with a light-emitting diode (LED) display.
Montseng Bereng @montsengbereng
評価: 2
投稿日: 2022年12月15日
hisense smart TV won't turn on. The red light underneath the TV is off as well.
How can I fix it?
この質問は役に立ちましたか?
1件のコメント:
Hi,
Have you checked that the power outlet that the TV is connected to is working?
If connected to a powerstrip (power board) connect it directly to the wall outlet and check if the red light turns on
Was there a storm or power outage just before the TV stopped working?
Please confirm the model number of the TV?
jayeff さんによる2022年12月15日
freeman @freemanuser
評価: 1
First plug in the outlet another device to see if the outlet is functional.
Then check with a multimeter (continuity test) if the cable is OK.
If the cable is fine, then most likely the problem is in the power supply
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 59
Hi,
jayeff さんによる
