Why is my tower's power LED blinking amber and not displaying?
Why does my computer's power LED keep blinking amber but doesn't display anything?
Then you need to remove the faulty unit and replace it with a good one. Just follow the procedure described at p.19 on the user manual, the size of the PSU you need to buy varies depending on the specific model you have, a common PS2 unit should fit into the tower, but you'd need an SFF unit (like this one) if you happen to have the smaller model. Here's a list of the most common PSU form factors.
Let us know how the repair goes and don't hesitate to ask if you need more advice
このアンサーは役に立ちましたか?
Many reasons that will give you a yellow light. What has caused this issue, it was working fine and all of a sudden it stopped - was there a power glitch?, have you moved the computer as sometimes the memory and or other connections inside get loose. I would open the box if you are comfortable - ALWAYS UNPLUG THE POWER. clean the inside of the machine and check to see if nothing has been moved and the memory is installed properly. Hopefully that should resolve the problem else you may have a bad motherboard and or a power supply that needs replacement. Take it to a repair shop if you you are unable to work on it.
このアンサーは役に立ちましたか?
It is probably a diagnostic code or it is in a sleep state, search up your model's manual on Google. Mind if I ask by blinking does it blink than stop or just continues blinking
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 4
過去 30 日: 12
今までの合計 1,074
6 件のコメント
Please check the user manual at this link https://dl.dell.com/topicspdf/optiplex-7..., p.45 (Power LED Diagnostics) and report back what's supposedly preventing the system from booting so that we can try to sort it out
Simone さんによる
It's the power supply unit failer
Ntuthuko Mbhele さんによる
Hi @Ntuthuko Mbhele You don't mention if the amber light is steady or blinking.
mike さんによる
The light is blinking
Hi @Ntuthuko Mbhele certainly looks like power supply as Simone says but would do as branda suggests reseating RAM, etc. and cleanibng dust out.
mike さんによる
1以上のコメントを表示
