メインコンテンツにスキップ
entire pre-lit Christmas tree won't light
entire pre-lit Christmas tree turned off and won't turn back on”
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
What model/brand Christmas tree?
さんによる
It is a 9 foot Frontgate tree, its 5 years old, I don't know the model.
さんによる
I changed the fuse it the tree plug ( took 225 5A fuse). it worked!! However, the tree still blows a Fues after a day or two. I just can't figure out why it started doing this, after 5 years. Help!
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi Donna,
Just because it's a pre-lit tree doesn't mean the lights are any different than any other Christmas light string, so check out the guide to fixing broken Christmas lights.
Fixing Broken Christmas Lights - iFixit Repair Guide
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
This is a 5 year old pre-lit tree, and I did replace all the bad bulbs,, which took 2 hours last weekend. It was lit, and then (like a switch was flipped), the entire tree turned off. I checked the outlet, and it is good. Its something with the tree, which is completely decorated :(
さんによる
Same here. Lights started flickering and wouldn’t turn off with foot controller. Had to unplug then lights wouldn’t work.. one of them!
Nancy
さんによる
meant to say none of the lights work
Nancy
さんによる
コメントを追加
回答を追加する
Donna Dubbs さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 4
過去 30 日: 5
今までの合計 317
