メインコンテンツにスキップ
The HP ZBook 15 is a powerful mobile workstation with advanced processing capability. Released in October 2013, this computer has the power and speed of a desktop in a highly portable package. Identifiable by model number F1M31UT. Most parts are easily accessible allowing for quick, simple repairs.
23回答 すべてを表示
Won't turn on at all have tried many things
Would turn on and off good all of sudden it wouldn't turn on I connect the charger and the light next to that turns on and stays on as long as it's plugged in but it won't start up I've removed the battery tried hard reset tried soft reset bought a battery bought new charger what should I try to do is there ways to test it the battery or the screens?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi,
It could be a faulty Power button.
You would need the schematics to be sure, but here's the maintenance and service guide for the laptop. Go to p.79 to view the procedure to remove/replace the power button board.
I don't know the actual pinout connections for the power button for the cable that connects it to the motherboard, but you should be able to work it out with an Ohmmeter once the cable is disconnected from the board by operating the button and checking for a short circuit between two of the pins which disappears when the button is released. If there is none at all between any of the pins then the button is faulty.
If the button is faulty the part number for the button board is found at the top of p.79. Search online using the part number only to find suppliers that suit you.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Oscar Valenzuela さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 15
今までの合計 88
