メインコンテンツにスキップ
The Hoover LiNX is a cordless vacuum cleaner. The vacuum uses interchangeable fade-free lithium-ion batteries that allows this device to be used everywhere and on multiple floor types. The Hoover LiNX uses Hoovers WindTunnel® 3 Technology which uses three channels for suction to suck up debris.
4回答 すべてを表示
turns on and quickly turns off
My Hoover LiNX coordless vac got caught on the end of a rug, did not catch anything in the blade, then turned off. When I turn it on again, after reviewing the rollers, etc, it turns on for quick second and then stops. Any idea what I can do to make my wonderful vac came back to life
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
If your Hoover LiNX cordless vacuum cleaner is turning on and then quickly turning off, there may be a problem with the motor or the power supply. Here are some things you can try to troubleshoot the issue:
  1. Check the power supply: Make sure that the vacuum is fully charged and that the power cord is securely connected to the vacuum and to a working outlet.
  2. Clean the filters: Over time, the filters in your vacuum can become clogged with dust and debris, which can restrict the flow of air and cause the motor to overheat. Clean or replace the filters according to the manufacturer's instructions.
  3. Check for obstruction: Carefully inspect the vacuum for any obstructions that may be blocking the air flow, such as tangled hair or debris. Remove any obstructions and try turning on the vacuum again.
  4. Check for damage: If your vacuum hit something or was dropped, there may be damage to the motor or other internal components. Inspect the vacuum for any visible damage and contact the manufacturer for further assistance if needed.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
RoseMary Cummings さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 31
今までの合計 322
